I can access the https://registry.terraform.io/.well-known/terraform.json through my web browser, but when I attempt to connect to it using the command line, I receive an error message that says “Failed to connect to registry.terraform.io port 443: Timed out.”
Do you have any suggestions for resolving this issue?
Thank you.
Askify Moderator Edited question April 24, 2023
