I have enabled split tunneling on the “TEST” VPN connection using the command “Set-VpnConnection -Name "TEST" -SplitTunneling $True -PassThru -ThirdPartyVpn” so that I can access the internet while connected to the VPN. The results are as follows:
ServerAddress         : https://test.test.com
Guid                  : {50DD97B3-E0F3-12ED-9F42-BE66495E28C5}
ConnectionStatus      : Disconnected
RememberCredential    : True
SplitTunneling        : True
DnsSuffix             :
IdleDisconnectSeconds : 0
PlugInApplicationID   : FortinetInc.FortiClient_45ggfgfgfj
CustomConfiguration   : #document
However, I am unable to connect to the internet despite having split tunneling enabled. How can
I resolve this issue?
Askify Moderator Edited question May 4, 2023
