Is there a way to take a screenshot of my second monitor using the command line (cmd/powershell) on my desktop computer with an extended display on two monitors?
Taking screenshots is a common task that many computer users perform. Screenshots are useful for a variety of reasons, such as documenting a problem or error, sharing information with others, or simply capturing a moment in time. However, taking a screenshot of a second monitor can be a bit more challenging than taking a screenshot of the primary monitor. In this post, we will explore how to take a screenshot of the desktop of a second monitor using the command line on a desktop computer with an extended display on two monitors.
Understanding Extended Display on Two Monitors
Before we dive into taking a screenshot of the desktop of a second monitor using the command line, it is important to understand what an extended display on two monitors is. An extended display is a feature that allows you to use two monitors as one large desktop. This means that you can move windows and applications between the two monitors as if they were one screen.
When you have an extended display set up, your computer sees each monitor as a separate display. This means that if you want to take a screenshot of the desktop of a second monitor, you need to specify which monitor you want to capture.
Using Command Line to Take a Screenshot of a Second Monitor
There are several ways to take a screenshot of a second monitor, but using the command line is one of the easiest and most efficient methods. Here are the steps to take a screenshot of the desktop of a second monitor using the command line:
1. Open the command prompt or PowerShell on your computer by pressing the Windows key + R and typing “cmd” or “powershell” in the Run box.
2. Type the following command in the command prompt or PowerShell window: “SnippingTool /clip”. This will open the Snipping Tool application and start a new snip.
3. Press the Esc key to cancel the snip.
4. Move the Snipping Tool window to the second monitor by dragging it to the desired location.
5. Press the Ctrl + Print Screen keys on your keyboard to capture a screenshot of the desktop of the second monitor.
6. Open an image editing software such as Paint or Photoshop and press Ctrl + V to paste the screenshot into the program.
7. Save the screenshot as a file on your computer.
Using Third-Party Software to Take a Screenshot of a Second Monitor
If you prefer not to use the command line to take a screenshot of a second monitor, there are several third-party software options available. Here are some of the most popular options:
1. Greenshot: Greenshot is a free and open-source screenshot tool that allows you to capture screenshots of individual windows, the entire screen, or a selected region. It also has the ability to capture screenshots of multiple monitors.
2. Snagit: Snagit is a paid screenshot tool that offers advanced features such as video recording, image editing, and screen recording. It also has the ability to capture screenshots of multiple monitors.
3. Lightshot: Lightshot is a free screenshot tool that allows you to capture screenshots of individual windows, the entire screen, or a selected region. It also has the ability to capture screenshots of multiple monitors.
Troubleshooting Common Issues
If you are having trouble taking a screenshot of the desktop of a second monitor using the command line or third-party software, here are some common issues and solutions:
1. The screenshot is capturing the wrong monitor: If the screenshot is capturing the wrong monitor, make sure that you have moved the Snipping Tool window to the correct monitor before pressing the Ctrl + Print Screen keys.
2. The screenshot is only capturing part of the screen: If the screenshot is only capturing part of the screen, try adjusting the size and position of the Snipping Tool window before taking the screenshot.
3. The screenshot is blurry or low quality: If the screenshot is blurry or low quality, try adjusting the resolution or DPI settings in your image editing software.
Taking a screenshot of the desktop of a second monitor using the command line or third-party software is a simple and useful task that can save you time and effort. By following the steps outlined in this post, you should be able to take a screenshot of the desktop of a second monitor with ease. If you encounter any issues, be sure to refer to the troubleshooting section for solutions.
Yes, there is a way to take a screenshot of your second monitor using the command line on your desktop computer with an extended display on two monitors.
One way to do this on Windows is to use the built-in command line tool called “Snipping Tool”. You can use the snipping tool to capture screenshots of your second monitor by running the command “SnippingTool.exe /capture /monitor 2” on the command prompt or PowerShell.
Another way is to use the built-in command line tool called “PowerShell”, you can use the command “Add-Type -AssemblyName System.Windows.Forms; [System.Windows.Forms.Screen]::AllScreens | % { [System.Drawing.Bitmap]::FromScreen($) } | % { $.Save(‘Screenshot’ + $_.DeviceName + ‘.png’, ‘PNG’) }”
It will take the screenshots of all the monitors connected to the computer and save them with the name ‘Screenshot’ + monitor name + ‘.png’ in the current directory.
You can also use third-party tools like Lightshot or ShareX to take screenshots of your second monitor.
The following untested PowerShell code snippet can be used as a starting point for capturing a screenshot of your second monitor on an extended desktop display. Keep in mind that the pixel coordinates for an extended screen are continuous across both screens, from left to right.
$File = "\mypath\myscreenshot.bmp"
Add-type -AssemblyName System.Drawing
# Gather Screen resolution information
$Screen = [System.Windows.Forms.SystemInformation]::VirtualScreen
$Width = ..2nd monitor width in pixels..
$Height = ..2nd monitor height in pixels..
$Left = ..2nd monitor starting left pixel..
$Top = ..2nd monitor starting top pixel, normally zero..
# Create bitmap using the top-left and bottom-right bounds
$bitmap = New-Object System.Drawing.Bitmap $Width, $Height
# Create Graphics object
$graphic = [System.Drawing.Graphics]::FromImage($bitmap)
# Capture screen
$graphic.CopyFromScreen($Left, $Top, 0, 0, $bitmap.Size)
# Save to file
$bitmap.Save($File)
