In the past, we had a Lenovo application on our Lenovo computers that prevented the battery from charging past 100%. Instead, it would discharge to 90% before recharging back to 100%, with the aim of keeping the battery in good condition for a longer period of time.
However, our current computers are Dells, and they don’t come with a similar app pre-installed. I looked into it and wondered if Windows 10 Enterprise includes a built-in feature that achieves the same purpose.
Maintaining the Health of Your Laptop Battery
A laptop battery is an essential component that determines the device’s portability and convenience. However, laptop batteries tend to degrade over time, reducing their overall capacity and lifespan. To maintain the health of your laptop battery, you need to ensure that you follow specific guidelines and best practices. In this blog post, we will discuss six essential tips to help you maintain the health of your laptop battery.
1. Avoid Extreme Temperatures
Temperature is one of the most significant factors that affect the health of your laptop battery. High temperatures can cause the battery to degrade faster, while low temperatures can reduce its overall capacity. Therefore, it’s essential to avoid exposing your laptop to extreme temperatures, such as direct sunlight, hot cars, or cold environments.
One way to prevent your laptop from overheating is to use a cooling pad. A cooling pad is a device that helps keep your laptop cool by providing additional airflow to the device’s bottom. Additionally, you can adjust your laptop’s power settings to reduce the amount of heat generated by the device’s hardware components.
2. Use the Right Charger
Using the right charger is another critical factor that affects the health of your laptop battery. Using a charger that is not compatible with your laptop can cause the battery to overcharge or undercharge, leading to premature degradation of the battery’s overall capacity. Therefore, it’s essential to use the charger that comes with your laptop or a compatible charger.
Moreover, it’s crucial to avoid using third-party chargers or counterfeit chargers, as these types of chargers can damage your laptop battery and other components. If you need to replace your laptop charger, it’s recommended to purchase a genuine charger from the manufacturer or an authorized dealer.
3. Avoid Complete Discharge
Complete discharge of your laptop battery can also affect its overall health and lifespan. When you let your laptop battery drain completely, it can cause the battery to degrade faster and reduce its overall capacity. Therefore, it’s essential to avoid letting your laptop battery drain completely.
One way to prevent complete discharge is to adjust your laptop’s power settings. You can set your laptop to hibernate or sleep mode when the battery reaches a specific level, such as 10% or 20%. This way, you can avoid complete discharge and extend the battery’s overall lifespan.
4. Keep Your Laptop Updated
Keeping your laptop updated is another essential factor that affects the health of your laptop battery. Updating your laptop’s operating system and drivers can help optimize the device’s hardware components, reducing the amount of power consumed by the device. This way, you can reduce the strain on your laptop battery and extend its overall lifespan.
Moreover, updating your laptop’s firmware and BIOS can also help improve the battery’s performance and health. Firmware updates can improve the battery’s charging algorithms, while BIOS updates can help optimize the device’s power settings.
5. Use Battery Saver Mode
Most laptops come with a battery saver mode that helps extend the battery’s lifespan by reducing the amount of power consumed by the device. Battery saver mode adjusts your laptop’s power settings to reduce the device’s hardware performance, dim the display, and turn off unnecessary features.
Using battery saver mode can help you extend your laptop battery’s overall lifespan, especially when you’re working on tasks that don’t require high-performance hardware components. You can also customize your laptop’s power settings to reduce the amount of power consumed by the device further.
6. Regularly Calibrate Your Battery
Calibrating your laptop battery is an essential process that helps improve the battery’s overall performance and health. Battery calibration involves discharging your laptop battery completely and then fully charging it again. This way, you can ensure that your laptop battery is accurately displaying its remaining charge level.
To calibrate your laptop battery, you need to discharge the battery completely, either by using the device until it turns off or by adjusting your laptop’s power settings. Then, you need to fully charge the battery, either by using the laptop’s charger or an external charger. Repeat this process every few months to ensure that your laptop battery is accurately displaying its remaining charge level.
Maintaining the health of your laptop battery is essential to ensure the device’s portability and convenience. By following these six essential tips, you can extend your laptop battery’s overall lifespan and improve its performance. Remember to avoid extreme temperatures, use the right charger, avoid complete discharge, keep your laptop updated, use battery saver mode, and regularly calibrate your battery. By doing so, you can ensure that your laptop battery remains healthy and functional for years to come.
It is not possible to overcharge a lithium-based battery even if it is continuously connected to a power source, as it has an internal circuit that prevents further charging once it reaches 100% capacity.
This means that any excess energy is automatically diverted to the laptop’s power supply system once the battery is fully charged.
