When I adjust the volume on my keyboard using the designated keys, a panel is displayed:
The volume on my computer can be adjusted using keys on the keyboard, with each press changing the volume by 2%. If I quickly press the increase key 10 times, the volume will increase by 20%. However, when I use the decreasing key, the volume decreases by 2% per press at first, but eventually accelerates to over 10% per press. This caused the volume to become too low or even muted when I tried to decrease it by 20%.
This issue is becoming very frustrating for me, and I’m wondering if there is a way to disable the volume decreasing acceleration feature.
Askify Moderator Edited question May 1, 2023
